Strapping 2 SAZ-3000D
Say i'm going to strap 2 of these bad mofo's (saz-3000d) and I have my 2 9515 d2 subs wired down to 2 ohms. What would the amp "see" would it be 1ohm each, giving each 9515 3k+ watts??? correct me if i'm wrong...or jacob please feel free to speak //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Yep, 1 ohm each is what it'll be.
That is a good bit of power for those subs daily (or any sub) so be careful.
Ive got a 300amp under the hood, big 3, a kinetik hc1800 under the hood, and 4 kinetik hc2000 in the back.......i think im good //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
oh and box is 12cu ft NET tuned to 35hz........stay tuned for a build log //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Just to re-iterate, be really careful with those 3000s on your DDs. Burping is no problem but on daily, music applications you'll be able to hit the mechanical limits pretty easily - especially in 12 cubes.
hmmmm.....well its going into the back of a 08 Tahoe..while i was browsing the DD forums I read that for really emphasized low end the 9515's like around 6 cubes....with as much power as im running what should the recommended box size be? size is no issue for me.... no comp's strictly daily ground pounder but i neeeeed that low end so any suggestions would be greatly appreciated!!
just got off the phone with chris from db-r......AWESOME GUY.......should have my 08 3000d shipped off by Friday //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif//content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif//content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif
IMO... more like 8 cubes + port displacement total. Still tune them to ~30-35 though.
It may be the case that 6 cubes is better for more low-end, but you have a TON of power on hand and you have to think about mechanical limits.
Thanks for your input Jacob, I appreciate it greatly......think it'll get loud? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Slikk
Banned
Slikk
M-DUB
sundownz
michigan born
    May 14, 2026
michigan born
    May 14, 2026
