stetsom and SD
Stetsom has been around for 20+ years and I believe SD started coming about 4 maybe 5 years ago? I'm not sure though so dont quote me on that.
From comparing boards, they dont look any different, only thing I could point out was that SoundDigital uses less of the electric grease.
I'll show you SounDigital 2500 and Stetsom 2k5 internals.
SOUNDIGITAL
STETSOM
we firmly believe that the difference is very big, and our amplifier has a PWM power supply.
Why only 2 rectifier diodes in the Soundigital amp? Seems like it would need 4 like the Stetsom. I see a few more rail and primary b+ caps in the SD amp. I would suspect similar performance though.
Can you ship me a SD2500 to test? Maybe a broken one and I will repair it in exchange for letting me test it?
don't forget the transformers...
Sorry, we don't have anything broken...
Yep, I see the visual difference having 2 large ones vs 1 large one should make it take longer to saturate it. Not sure if the output section would be able to switch any additional current it might produce however. If you don't have a broken one, send me one that works, a used one. I would like to play around with it for a couple days.
TnT_Sounds
profiling gets **** done!
TnT_Sounds
Colorado
ninjawhiteboy12
