dtbrown
I'll make this clear now since most people won't read to far into post and only look at numbers. This is only a spl and power comparison test. The NSB90 battery used in test is a 4 year old NSB90 that is about .5db down from newer NSB90. The battery is good for burps but doesn't have the the amps it used to. CS9000 is almost new.
This test is to compare 7KD 16v, 7KD 12v and new 7K2D modified 12v version.
NOTE: Seven 2200mf capacitors added to 7K2D to make it a 12v version. Standard 7K2D is as strong as the older 7KD 12v and more efficient.
7KD 16V @.5ohms Only mod is copper bars instead of fuses.
NSB90: 3200-3300w, voltage drop 10.7v, 153.0db
CS9000: 4200-4300w, voltage drop 11.3v, 153.8db
Video
http://s171.photobucket.com/albums/u307/dtbrown1978/?action=view&current=SANY0399.flv
7KD 12V @ .5ohms
NSB90: 4000-4100W, voltage drop 10.4v, 153.5db
Video
http://s171.photobucket.com/albums/u307/dtbrown1978/?action=view&current=SANY0400.flv
CS9000: 5000-5200W, voltage drop 10.7v, 154.3db
Video
http://s171.photobucket.com/albums/u307/dtbrown1978/?action=view&current=SANY0404.flv
7K2D Modified 12V @.5ohms (Seven 2200mf capacitors added. Standard 7K2D is as strong as the older 7KD 12v and more efficient)
NSB90: 4200-4300w, voltage drop 10.3v, 154.0db
Video:
http://s171.photobucket.com/albums/u307/dtbrown1978/?action=view&current=SANY0410.flv
CS9000: 5500-5600w, voltage drop 10.7v, 154.7, 154.8db
Video: Explains why there is more spl gain but not much power gain vs the 7kd 12v.
http://s171.photobucket.com/albums/u307/dtbrown1978/?action=view&current=SANY0412.flv
http://s171.photobucket.com/albums/u307/dtbrown1978/?action=view&current=SANY0417.flv
Conclusion: You'll notice that the 7K2D only does a little more power than the 7kd 12v but does .5db louder. The power tests doesn't relate to the spl gain. Watch the videos because it'll show that even though the amperage is close to the same as 7kd 12v the spike voltage on the 7K2D is very high compared to the real time voltage. The amp wants to make more power but is unable to due to battery limit. And the 7k2d holds it's power vs the 7kd 12v falls off 4 volts after initial burp. That's some of the reasoning for that. I could have used the spike voltage for my power test but it was never consistent and would have given me power from 6500-7000w. So I decided to use the real time voltage because it was very consistent but I still recorded box spike and real time voltage if anyone wants to know what the spike voltage was. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
But that the new 7K2D 12v is more efficient than the older 7KD by a lot. The 7K2D has same voltage drop as older 7KD 12v and is .5db louder shows it's efficiency. This amp wants to produce even more power and I can see this amp easily producing it's rated power at 12.6v. Fantastic job Stetsom. You really needed a more efficient amp and you went above and beyond that. Can't wait to test it at 1ohms for music on two CS9000's vs 7KD at 1ohms for music.
Video
7KD 12V @ .5ohms
Video
Video
Video:
