Stetsom 14k2d
nice amp rob!
so it can make full power on 400-500amps of current cause that is bout all a single piece on 0gauge can give for more than a couple secs.
i know the 7kd couldnt hold together off a single battery so that amp drew more than 300 amps. so the 14k draws less than a old 7kd???? please explain someone i am curious...
nice amp rob!so it can make full power on 400-500amps of current cause that is bout all a single piece on 0gauge can give for more than a couple secs.
It's a Stetsom....................ohms law and gravity have no effect on it.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Because it doesn't need two and is proven to put out rated with one. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Insane amounts of current still have to go through the wire...does it not seem odd that this amp, which does roughly 10 times that amount of power as a SAZ-1500D, has the same sized power input? Power is power, it requires X amount of current, regardless.
Ryan check out the amount of copper thats on the board. This could be a major reason why 2 inputs are not needed.
But there still has to be who knows how many amps being drawn...1000? Maybe more? I hope you have 4 runs of 1/0 going to the back and a little 2" piece of 1/0 going to the amp...I honestly don't see how it's physically possible to run 1000+ amps through any length on 1/0.
i machined a adapter so you can put 2 0g wires in 1 0g hole. it would be a MUST on this amp...
u can draw up to bout 500amps off a couple foot of 0g.
maybe they are using the 0g like a fusable link,LOL...
thorshammer1
thorshammer1
Auburn, NY
hrtbrk1
