Stereo wont come on unless both ingition and memory wire are connected together.
drips702
I have a 2005 magnum and i bought an aftermarket stereo with dash kit.
Everything is hooked up correctly(i think) and from what i have read the magnums do not have an ingition wire (red) even though its included in the harness. So from what i have read i needed to tap into the cigarette lighter to receive ignition power.
My problem is that when i do this i het no power, i figured out that the only way i get power and get the stereo working is if i connect both ignition and memory power wires to the same 12v cigarette lighter. My stereo works i just cant save presets
Anyone know what is the problem? I have a left over "illumination" wire but it wont work.
So my understanding is that you don't have an ignition wire so you have to hook up the red to the cigarette lighter. Your yellow needs to be hooked up to a constant power (usually yellow from the adapter if you have one). If you hook both red and yellow from your head unit to the cigarette lighter, then your presets will not get saved as the power to that source turns off when you turn off your car. The illumination wire goes to the illumination wire on your adapter. If one is not available, then just tape it up and forget about it.
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
228
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
355
There is a good chance you could add some sort of Bluetooth or AUX input to a vintage stereo such as a 1978 Pioneer, maybe with a separate toggle...
584
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
drips702
drips702
ThxOne
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
