Steal...
You're a fucking joke. An assclown who insist on trying to prove to everyone that you know everything yet all you do is make yourself look dumber with each and every post. Why don't you gtfo and gfys.
Im the one schooling you dumbfucks.
Look at eevey nec based site. Ive actually taken test to ve certified to do thi **** dumbfuck.
I'm sure he has a "chart or article" somewhere that would disagree with your findings.
His findings? Ill bet ypu anything you want you get a 3 foot 1/0 measure 550 amps through it check voltage on the line side then load sid and you get 5% voltage loss and that wire gets hot as ****..
Reason being its not so apparant is because your NOT SEEING that power unless you get a true one OHM load which is hard to do with a reactive and dynanic load.
One second of overcurrent isnt going to hurt like a static load but your still going to get voltage drop over the conductor..
Since you know better than the NEC you should be making 80 a hour being an inspector.
disturbed471985
disturbed471985
Greenwood, La
Papermaker85
