Timbo42k10
---I'm getting this static sound coming from my front and rear speakers. You can barely hear it with the inputs to their respect amps at 0 and HU volume turned all the way up, but as you increase the input and max it out, it's pretty loud as you increase the HU volume.
---I've got a 0 gauge wire running to the back power distrubtion block with (3) 8 gauge wires out the other end going to my seperate amps. I have 3 street wires zero noise rca, which I ran all the way back to the head unit and draped it over the top of the seats to insure they weren't the issue. Everything is grounded under 18" of ground wire length; the 2 front and rear speaker amps are grounded under the same bolt and the capacitor to sub amp ground is about 2" away from the other ground. The ground are located on the chassis of the car between the trunk and rear seat hatch area.
---The static noise is loud on FM frequencies and with audio going through, the music is greatly distorted at high volumes whereas on CD the static is there, but about 70% less and I can nearly max out my inputs and have it crystal clear BUT I mean the static IS still there, toleratable though.
---Anyone have some input on this? I had just made this account because of this issue but look forward to posting more on here and hope someone has some advice! My detailed audio info is on my signature. Thanks in advance!
