standard cab S10 sub questions
99StangGt
I have a standard cab S10 and want to put a sub or 2 in it. Problem is space. I have 2 8" PG tantrums but now thinking maybe 1 10" would be better because the box could be bigger. Also depth can be an issue. I also will be installing a Cadence TXA6004 amp and that will take up 25" of space. Anyone have any suggestions?
i ran two 10w0 jl audios in a 95 s-10 in a .75 cu. ft. per sub sealed box by removing the jack bracket from the back of the cab and building the box as wide as i could. also when you design your box try lowering the sub in the box as far as possible.(the lowest screw in my subwoofer was into the bottom panel of the box)
99StangGt
99StangGt
Oregon
dragon.breath
