Stand Alone Alt.
Gearstix
I got a 2005 V6 Chevy Blazer. 4.3.
I may figure out how to make a bracket to bolt up a second alternator.
I'm just wondering is the a GM alternator that I can use, that is stand alone and not computer controlled, so I can run it right into my buss bars in the back? Would this be a 'one wire alt'?
when adding an extra alt using the one wire ford or GM unit you will need a small light bulb in line on the exciter wire to give about a half ohm resitence this will triger the alt on . a second alt is easily done if you use a second battery. if not using a second battery it turns into a real headach that isnt even worth going into talking about. this is kind of a side note but goes along with alternator installs and big three info the size of wire from battery to alt should not be larger than 6 guage acording to some alternator manufactuors because they claim the larger wire will burn out the first diode.
no...atleast not the way i have learned it. A one wire is just that, one wire and you have nothing else to mess with. Now when you start using other alts with multiple connections you will need a bulb or resistor inline with an ign hot wire. You do not have to have a second battery to run another alternator? although most who use another alternator have way more then 1 battery
yep your right i got off the one wire alt story and into stock alts somehow. and i wasnt saying you have to have a second battery i was saying that it is less complicated to have each alt runing to a different battery. i have done it both ways and i like having mine set up like two complete different systems.
Gearstix
Gearstix
Alberta, Canada
sexy
NorthFramingham
    Jun 30, 2026
