stacking fuses
dmz2711
FL
Lets say i wanted a 500amp anl fuse... Is it possible to stack (2) 250amp anl fuses on top of eachother in the same fuse holder to equal 500amps??? does that even work??//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
hmmm. i doubt it would act as a 500amp fuse. now if you were to have 2 seperate runs of wire. one 250A fuse on each wire then. I think it would act as a 500 amp fuse
ok thanks, but what if an amp needs to have an external fuse of 500amps and it only takes 1 run of wire, how can it be done if you can't find 500amp fuses???
dist block? one big big wire then out to 2 smaller(1/0) wire. but what amp do you have that needs a 500 amp fuse?//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
you can get up to 750amp anl fuses here.
http://www.outbackmarine.com.au/masterpages/TypeDetail/TypeDetail.asp?TypeID=39
But it better big alot bigger wire then 1/0 gage.
thanks for the link! i knew you can get fuses up to 500amps, but had no clue about 750amps. Either way, i am wondering if stacking the 250 amp fuses is possible. The amp will either be a memphis 4kw or RFT4000, but what i wanted to find out, is that it is even possible?????????//content.invisioncic.com/y282845/emoticons/ponder.gif.ec2527b23f1d287b60dcbba54f95edba.gif
No need for a 500 amp fuse for either of those.
why worry about what fuses the amps need? the inline fuse is for the wire not for the amps.
ok, i am really wondering one thing, and that is... is it possible to stack 2 fuses together in the same fuse holder???? i have had some people say yes, and some people say no.. anyone have an idea???//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
dmz2711
dmz2711
FL
Cam
NorthFramingham
    Jun 30, 2026
