BNIB SSA Gcon 12D4
1 pair RE Audio RE8s D2
JL Audio 8W7AE Single 3ohm
ONE 12" SSA Gcon 12D4, BRAND NEW IN BOX
Coil(s) 3" wide, 4 layer,aluminum coils
Terminals Push terminals
Cone Pulp Fiber Cone
Cooling CNC Machined Aluminum Cooling Plug
Suspension Dual Nomex spider pack
Motor FEA optimized motor
Former 3" Anodized alum. former
Lead Wires Triple Sandwiched Leads
Hand Crafted in USA
Fs 31.5 Hz
Qms 6.50
Qes .58
Qts .53
Mms 183 g
Sd 481 cm^2
Vas 45.2 l
Bl 19.01
Spl 85.7 1W/1m
Xmax 20mm
Wattage 750wRMS
Displacement 0.15cuft
RE Audio RE8s. NOS, with a few minutes test time. These are old school original RE8s, not the crappy new stuff.
Product Dimension 8"
Mounting Depth - 4"
Mounting Hole Diameter - 7.125"
Overall Diameter - 8.25"
Bolt Hole Circle - 7.75"
Motor Width - 4.875"
Motor Depth - 1.5"
Basket Depth - 2.5"
Displacement - 0.07 cu. ft.
Weight - 6 lbs.
T/S Parameters 8"
Electrical Q Value -Qes: 0.38
Mechanical Q Value -Qms: 4.21
Total Speaker Q Value -Qts: 0.34
Free Air Resonance -Fs: 22.8 Hz
Equivalent Compliance -Vas: 27.1 liters
One-Way, Linear Excursion -Xmax: 12 mm
Efficiency -SPL 1W/1m: 81.2 dB SPL
Effective Piston Area -Sd: 195 cm^2
DC Resistance -Re: 3.2 ohm
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 175 W
JL Audio 8W7AE, used with about 10 hours play time in JL spec'd enclosure on 300 watts.
8" Single 3 Ohm W7 Subwoofer
10th Anniversary Edition
Power Handling:
Peak: 1000 watts
RMS: 500 watts
Recommended Power Range: 125-500 watts
Impedance: Single 3 ohm
OverRoll Surround
W-Cone
Floating-Cone Attach Method
Plateau-Reinforced Spider Attachment
Radially Cross-Drilled Pole Piece
Massive Forced-Air-Cooled Aluminum Alloy Frame
Highly Linear, DMA-Optimized Motor System
Huge Diameter, Progressive Roll Spider
Co-Extruded Double Lead Wires
Black powder-coated baskets
Bright nickel finish clamp ring
Unique Anniversary Edition badging and labeling
SSA Gcon 12----$210 shipped anywhere in the continental 48 and no wait.
RE Audio RE8s---$110 shipped anywhere in the continental 48.
JL Audio 8W7AE---$260 shipped anywhere in the continental 48. I will also sell local or pickup with the enclosure included.
If paying by PayPal, you must cover fees or send money as a gift. I will ship the day after payment is received unless I have time to get them out ahead of that. All items sold as-is, no returns.
More photos can be found here so as not to clutter the thread.
FOR SALE Photos by tirefryr | Photobucket
BNIB SSA Gcon 12D4
Hand Crafted in USA
Fs 31.5 Hz
Qms 6.50
Qes .58
Qts .53
Mms 183 g
Sd 481 cm^2
Vas 45.2 l
Bl 19.01
Spl 85.7 1W/1m
Xmax 20mm
Wattage 750wRMS
Mounting Depth - 4"
Motor Depth - 1.5"
Basket Depth - 2.5"
Weight - 6 lbs.
T/S Parameters 8"
Power Handling:
Peak: 1000 watts
RMS: 500 watts
OverRoll Surround
W-Cone
