SS RL-p & ED Nine.1
Would it be better to buy the SS RL-p Dual 2 ohm subs
They are not available from Soundsplinter. Only D4's.
and run them off of the nine.1 with around 900 watts a piece, or buy the dual 4 ohm subs and run them at 1200 watts a piece.
Your post is confusing. How many subs are you going to have, one or two? How many Nine.1's, one or two? You refer to the subs in the plural sense, and the amps in the singular sense. But, then you refer to 1200w "a piece", which would not happen with two subs and a single amp since they would share the power.
Just to let you know, going from a W7 to a RL-P is a Huuuuuuuuuuge downgrade, why not get an RE XXX? It would be fine in that box.
Why are you giving anybody tips?
You made a thread claiming you had the best system ever (literally), 5 seconds later you talk about your system doesn't sound good cause of a headunit switch.
Just stop.
sorry i wasnt specific earlier, i figured it out on my own. And LS1 the reason im changing from an 1 W7 sealed, to, 2 RL-p 12's sealed is because, the box for the W7 is to big to fit behind the seat and i need all the space i can get in my single cab.
Oh ok, 2 RL-P's should be fine. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Why are you giving anybody tips?You made a thread claiming you had the best system ever (literally), 5 seconds later you talk about your system doesn't sound good cause of a headunit switch.
Just stop.
Sad, but true. Also how big of box did your dub7 need? I just don't see how the 2 12s will need less space.
edit... x2 on the enclosure specs each or both??
^^ Well see the problem with the W7 is that the mounting depth is to deep to physically get a big enough box behind the seat. The RL-P's mounting depth is around 6 9/16 IIRC Wheras the W7 mounting depth is 10.5 inches. Also each RL-P will be in 1.4 cubes (Separte Chambers), so the total box will be a little over 2.8 cubes.
Chevyaudio
:poof:
Chevyaudio
Back in the Dirty BR, Louisiana
Chevyaudio
