SQL sub single voice coil
hi i'm looking for a single voice coil pair of 12" subs to use them with a 500wrms alpine amp 2OHM something without braking the bank...
If all you need to do is run a pair at 2 ohms, you have many other options than using svc 4subs. for example you could use (2) dual voice coil 2 ohm subs.
Current and resistance
A series circuit is a circuit in which resistors are arranged in a chain, so the current has only one path to take. The current is the same through each resistor. The total resistance of the circuit is found by simply adding up the resistance values of the individual resistors:
equivalent resistance of resistors in series : R = R1 + R2 + R3 + ...
A parallel circuit is a circuit in which the resistors are arranged with their heads connected together, and their tails connected together. The current in a parallel circuit breaks up, with some flowing along each parallel branch and re-combining when the branches meet again. The voltage across each resistor in parallel is the same.
The total resistance of a set of resistors in parallel is found by adding up the reciprocals of the resistance values, and then taking the reciprocal of the total:
equivalent resistance of resistors in parallel: 1 / R = 1 / R1 + 1 / R2 + 1 / R3 +...
aleborjas
aleborjas
Miami, FL
rosrock
