SQ and SQL that rivals 10W7
Originally posted by nismboy6986 anybody know the theile/small parameters on the W7? I can't find it on their site and all they do is ramble on about the technologies of it. Are you sure that 32mm xmax is true DUMAX vertified Xmax or just theoretical xmax? since it obviously has more cone area than a Brahma wouldn't 32mm of xmax make it louder?
Just go a search on Thiele/Small parameters for W7 on google or something, I'm sure you can find it.
I believe that the W7 had a vdery close xmax to the theoretical of 32 mm on the Dumax...
Originally posted by Jeremy jl fan Ok nobody has mentioned the boston acoustic c110.....
how much do those run? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
-nate //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Originally posted by brad.farmer The simple answer is this, Image Dynamics IDMAX. It is a 12" sub, that handles 1,000 RMS, and goes down to something like, 22 or 23 Hz. I have heard it too, this sub delivers! It has high Xmax, good SQL, and awesome SPL. This sub will not fail you. Plus, it is cheap. You can find it for about $310.00. Truly, this is the sub. Though 13w7, is a tad better. This sub gets lower than the w7s, though. Just about the same Xmax, and pretty much the same SQL and SPL.
brad.farmer
have you played with the W7 yet? if so..how long? what box? how much power? same goes with the idmax. what box? how much power? seems like you don't have a lot of experience with neither of these subs.
the idmax is able to respond down to 2hz, just like almost any other sub can.
Open up the PDF thing at the bottom of the page...
- Steve
Code:
I'm still trying to figure out this part.//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
danfortner
danfortner
Mystic, CT
wesleysh
