All of these items were professionally installed in my old car (g20)... I have pictures of the items actually installed or can take more pictures as each item is now-for serious buyers.
Any questions feel free to PM me or text/call at 7084940441
Will consider reasonable offers
Located in IL... Can work out shipping if necessary
Full gallery of pictures
http://gallery.mac.com/jonathan0702#100310&bgcolor=black&view=grid
JBL W12GTI MKII = $275 NOW - 245 >>> $245 SHIPPED
Technical Specification
* Sensitivity: 91 dB
* RMS Power Range : 700 Watts
* Peak Power Handling: 4000 Watts
* Impedance: Dual 6 Ohm
* Low Frequency response: 18 Hz
* High Frequency Response: 1000 Hz
* Diameter: 12 Inch
Features
* Differential Drive Design (DDD) motor
* Die-cast vented basket
* Kevlar impregnated paper woofer cone
* Nitrile-butylene surround
* Cut-out diameter: 11"
* Mounting depth: 10-1/4"
JBL GTO1201.1 MONO amp = $230 NOW 200
787W RMS x 1 channel at 4 ohms and ²1% THD + N
Signal-to-noise ratio: 70dBA (reference 1W into 4 ohms)
1114W RMS x 1 channel at 2 ohms, 14.4V supply and ²1% THD + N
Dynamic power: 1339W at 2 ohms
Effective damping factor: 6.348 at 4 ohms
Frequency response: 10Hz – 302Hz (–3dB)
Maximum input signal: 6.1V
Maximum sensitivity: 75mV
Output regulation: .14dB at 4 ohms
Dimensions (L x W x H): 18-11/16" x 12-5/16" x 2-3/8"
Fuse rating: 3 x 40A
JBL GTO75.4 4 channel amp = $215 NOW 190
4-channel car amplifier
104 watts RMS x 4 at 4 ohms (142 watts RMS x 4 at 2 ohms)
284 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
variable high- and low-pass filters (32-320 Hz, 12 dB per octave)
bass boost (0-12 at 50 Hz)
MOSFET power supply
preamp-level inputs and outputs
speaker-level inputs
CEA-2006 compliant
fuse rating: 30A x 2
Play Station 2 with accessories = $150
with custom car mounting box
2 Wireless controllers
400 watt inverter
Also, I have a Head Unit... I can take picture for anyone interested
Sounstream VIR-7011N - $245 >> 190
7" Wide Touch Screen 1-Din Oversized Fully Motorized TFT Monitor/DVD/AM/FM
* Diameter: 12 Inch
Features
MOSFET power supply
CEA-2006 compliant
400 watt inverter
