Split between a few amps for two 12w7's
xjust1n
7
NC
So I just got two 12w7's in a sealed box and i'm going to need an amp soon...
I'm kinda split between these three
-Crunch GroundPounderV2000.1D
-Crunch P1500.1
-Orion Hcca-D2400
I'm almost set on a A/B amp not class D. I plan on getting a better amp later on but just need one to run these babies for now.
Which one do you guys suggest? Thanks!
Yeah i'm trying to, right now I just want to get a decent amp for less then 250-300 and i'm trying to separate the crappy amps to the good ones.
I doubt your going to find 2000watts for that cheap. You'd have better luck it you raised it to about 375-475$$.
Look for something like a sundown 1500d, rd 1750.1, these are both zenon based amps that are underrated, and will have the power to push those jl's. They are also usually available for ~300 used, and are very good, high quality amps.
Edit: You will probably not notice a sound difference between a/b and d class, also a 2k a/b amp will play havoc with your electrical, as it requires a LOT more current than a comparable class d. Also look for an IA 20.1.. another great amp and there is at least one on the classifieds right now.
What do you mean zenon based? I know zenon amps are beasts, making the same power from 1-4 ohms and underrated. Are the sundowns and rd's like that also? Kinda confused when you say zenon based...
xjust1n
xjust1n
NC
jpexpc
