Spl
u not going to get 17 volts out of your truck without some costly modifications,plus u dont need it,all u need is high output alt,and some hc batteries,and run some ought guage wire to ur amp.
mono = 1 channel, stereo = 2 channel, 3+ channels is usually refered to as multi-channel
generally in car audio, mono amps use class D circuitry which is more efficient (less current draw to produce the same wattage) than class A/B amps (but low SQ compared to A/B), because of this class D amps are more suited for powering subs due to the relatively high amounts of power needed for subs.
Magnatus
Banned
Magnatus
AZ
xtremebassjunky
