Spl Ml12w?
Bump, and what about the Crunch "Ground Pounder" GP12D4? I can get both for about the same price with Crunch being a lil' more expensive. I haven't heard anything bad about these Crunch subs, so would it be better to go with the Crunch or the SPL?
Ok, where to start...
I guess I should mention that the first subs I ever owned were SPL ELF 15's. They were decently loud but left a LOT to be desired in every other way. Considering the brand itself I would not buy those.
Crunch is a totally different story. You don't "not consider buying" Crunch woofers, you just don't buy them. Period. They are a waste of good magnet and copper in my own opinion.
If you want loud on a budget, check out Mach 5 Audio at http://www.mach5audio.com. They are by far better woofers than what you have mentioned and should cost less money as well.
Good luck.
Good luck.
So, have you bought/heard/owned the ground pounder series subs? I have heard complete different suggestions on them, and that I should buy them.
TreblePhobia
TreblePhobia
Inside A Speaker Box.
TreblePhobia
