SPL competitors, how many runs from front to back
thegreatestpenn
lazy genius
just as the title states, now many runs of O do you have going from the engine to the back of your car (or from primary battery to the back batts). Also how big is the hole in your firewall for that wire and did you cut one or use factory holes? Just curious as to how far behind I am with currently having 1 run of 0 from front to back
4 runs total (2+ and 2-). The hole is probably 2" in diameter.
I didn't gain anything going from 2 runs to 4 runs, but then again i'm not running much power either. But that will change in the (hopefully near) future. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I had 16, no fuses of course
ScottieJ recommend me minimum of 4 pos 4 neg if you're pushing large power for those short burps. I did fine with 3 pos 3 neg....but essentially the more the merrier.
I used to have 6 total...retired now working with a rex, with far more wire //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
Edit...cant see the third run...its out of the bottom of the picture...those D-blocks have 6 wires in them each.
thegreatestpenn
lazy genius
thegreatestpenn
columbus
Lakota
