SPL Box?
and find out what your car peaks at and tune a couple hz lower.
Small box big port tuned high. Thats what spl boxes are
not always. sometimes its big box big port its all dependant on how it will be used.
mdf is (imo) the best for small spl builds and birch/pine for bigger walls and such. usually aeros are used so you can change tuning whenever
Big boxes are for people that dont have enough power to get there sub loud. The bigger boxes allow them to produce more sound on little power. Little boxes allow the sub to handle more power
And birch is a far better material to use. They are about the same density as mdf but the weight you save and how much stronger birch is makes a huge difference. Birch is much easier to work with as well. Cuts so much easier.
If he wants to get real fancy he can use steel or granite
exactly the point //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif but on small spl builds mdf wil lbe more effective for the cost. birch is 51 a sheet here and sorry im not goin to pay that to lose 30 lbs lol
Go to someone with a termlab and have them check it. You will want to do all your sound deadening and other major modifications for SPL finished before you get it checked. But when you have the resonant frequency of an exterior enclosure(vehicle) you pretty much just put a sub(usually a 12") in a sealed box inside the vehicle at different locations all while running frequency sweeps and graph the results. The sweeps are usually just 20 hz to 80hz, and peaks in SPL, at certain frequencies denotes the peak resonant frequency.
But as mentioned before, certain factors will change the resonant frequency drastically, such as but not limited to, air temp, humidity, fat chick in front seat, and even something as small as the visors being down. This is why most people will just run a box with an aeroport because the ability to change the port length and tuning is easier. Hope this helps!
Well my set up will be:
(2) RE SX 15" D2
(2) Hifonics BRZ 1200.1D
(1) Kinetik khc1400
(1) Singer 200A alt
0 gauge knuconceptz (big 3)
4 gauge knuconceptz (amp wire)
8 gauge CCA (speaker wire)
25sq ft audio technix deadener
You should be able to pull some descent numbers with that set-up, but you are definitely gonna need more power. I would check out the rule book for the sanctioning body you wish to compete in. Like in USACI, the cutoff I believe would be 2,000 to 4,000 watts in modified and super modified. It wouldn't help you any to run this category with 2,000 when everyone else will be running max at 4,000 watts. It would be hard to stay competitive. And just to let you know, USACI also doesn't use the 1 ohm power rating to classify you. You will be put in your category according to what your amp puts out on one channel at 4 ohms. which would be 450 watts per BRZ which gets you to 900. You could probably run 2 more of those amps and be at 1800 watts and qualify for the Stock 601-1800 watt division. Here is a link to there Rule book:
United States Autosound Competition International (USACi) - Store Order Form
It's really not hard to compete and be successful, just make sure you have a really good enclosure designer. When it comes down to it, the enclosure will make it or break it for you. I hope you can find some really good shows to go to. There are some really good folks out there that do this and are really good people to have as friends. I hope this helps you some more!
dfoland93
dfoland93
Lake Forest, Ca
Joseph7195
