Speakers don't sound loud enough
Leenix
22
Cy
I have 2 x Daytona DCS812's ( 8 x 12 ) 150W RMS - 500Peak
And a 700Watt Cadence Amp.
My problem is that my friend's cars which have stock factory speakers and for some reason, their speakers sound both better and louder.
If i try to turn up my speakers a bit i start getting some distortion in the lower frequencies.
Could i be missing something very very basic here?
I also have a Plutonium GZPW 15XQ 5k Watt running on a separate 4k Watt Monoblock InPhase Amp which sounds just fine....
deadening isn't as important as seals. factory speakers have excellent seals. aftermarket installs have no seals. you need to add weatherstripping foam to the back and front of the speakers to create seals. the thickness depends on the install. use the OEM speaker as you guide for the thickness of foam required.
Leenix
Leenix
Cy
keep_hope_alive
