jeffrey_martin
Registered User
I have a set of MTX component which are rated at 90 watts RMS. I already have a spool of 18 gauge wire, so will it be big enough?
Yes they will be powered by an amp. I have enough 16 gauge wire to run from the amp to the crossovers, but from the crossovers to the speakers I was going to use 18 gaugeare you powering these from an amp?
18 gauge is big enough.Yes they will be powered by an amp. I have enough 16 gauge wire to run from the amp to the crossovers, but from the crossovers to the speakers I was going to use 18 gauge
test it?18 awg wire u might as well be using dental floss not bashing but thats pretty small wire gauge for componets...i use 12 awg on the componets the bigger wires lets u get better fidelity and less resistance..
