speaker setup for 02 blazer 2dr.
SCIVIC94
if it isnt broke,modify
i am looking to completly redo the system in my truck. i already have a alpine cda 117 headunit and will be using a soundstream rubicon 4.500 4channel amp .
for bass i have a soundstream rubicon 1.1600 and it will be powering a pierce audio 12"wmd
specs on the 4.500 are
Power Output: RMS Power @ 4 ohms: 75 watts x 4 RMS Power @ 2 ohms: 125 watts x 4 RMS Power @ 4 ohms bridged: 250 watts x 2 THD 0.015% Signal Sensitivity : 0.2V -6V 50HZ Bass Boost: 6 or 12dB 35 Hz Subsonic Filter Infinitely variable crossovers w/ multipliers (High/Full/Band/Low) Mosfet PWM power supply IDI intelligent distress indicator
what i am looking for is to replace the 6.5's in the front doors and the 6x9's in the rear. the front doors speakers are located in the low fron of the panel and the rear 6x9's are abour lower chest level aprox 2.5 ft back from front seats.
i wanted to do 6.5" components in the front doors and thought about also doing 6.5" components in the back. my buget is about 150-170 per set.may stretch slightly higher if need be.like something that has good clear mids with a warm tweeter that is not to shrill or tingy. any help is appreciated
you may need to bump your budget a bit ,unless you get used or close outs .i do have a set of cdt com 626 speaker package ,6.5 components for the frt and 2 ways 6.5 for the rears for a great price .pm me if interested .i can keep it in your budget
i might be able to bump my budget a hair i guess it depends on how much. trying to keep it around 300 all around as that is what i have now. i may be able to scratch alittle deeper.
pm me all the info and the price. i cannot find find any indepth specs on the set up. i just dont want to jump in without seeing all my options. my budget can be stretched if need be.
SCIVIC94
SCIVIC94
ELIZABETH , NJ
SCIVIC94
