Speaker Mounting Depth Question???
jt34237
I'm going to be getting these comps installed-
CTX65CS - Image Dynamics 6.5" Component Speaker System
I currently have these installed
SPS-500 - Alpine Type-S 5-1/4" 2-way car speakers
I'm going to be upgrading to the larger size for the front speakers, from 5 1/4 to 6 1/2. My concern is in regards to speaker mounting depth. The alpine coaxials have a mounting depth of 2", the ID's have a mounting depth of 2.75". Is there a way to make the ID's work? How would I find out the max mounting depth of the speaker ports for my car? Thanks! //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
might wanna let us know the vehicle someone might know if they will fit just as is.
also could use the what will fit my car option on crutchfield and see what the depths are on the speakers that are listed.
not too hard to figure out....
might wanna let us know the vehicle someone might know if they will fit just as is.also could use the what will fit my car option on crutchfield and see what the depths are on the speakers that are listed.
Tried the cruthfield method, it tells me that I use 4" speakers in the front doors which is incorrect. The factory speaker ports are 5 1/4. The car is a 95 Geo Prizm.Again the alpine type s coaxials fit which have are 2", my question is how much more room do I have then that and how do I find out? And if I don't have enough room is there a way to make it so that the speakers will fit without sacrificing SQ.
nope there isnt a way, any other method is going to ruiin all the sound quality. best option is not to....
528
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
463
625
536
jt34237
jt34237
Sarasota, Fl
Horsemanwill
