Speaker Install Help
  • 2
nawcor
I'm installing new door speakers and I'm running new speaker wire to the amp on a stock radio.
Do I run the new wire just off the speakers themselves straight to the amp or do I split them from the stock radio wires and then run them to the amp?
It's been awhile since I've done an install and I can't seem to remember the answer.
You just run the wire to the amp. The amp has connections either through RCA cables or high wire that go from the head unit to the AMPLIFIER. The AMPLIFIER takes the signal from the head unit, and AMPLIFIES the signal sending more power to the speakers. If you were to wire both, you would be trying to take the same input from the head unit and the amplifier. Not sure how that would work, either playing both signals and sounding like it was a constant echo, or the amplifier may drown it out. Either way, Just wire the speakers through the amplifier.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
101
144
nawcor
nawcor
Florida
HardofWhoring
slater
    May 2, 2024
slater
    May 2, 2024
