Viti
Is this a good combination for these speakers?
2 of these:
KICKER S15L7
15" subwoofer with dual 4-ohm voice coils
Power range: 50-1000 RMS watts
Peak power: 2000 watts
Frequency range: 18-100 Hz
Sensitivity: 88.5 dB
SoloKon aluminum-treated composite cone with Santoprene surround
Cast-aluminum basket
Mounting depth: 8-3/16"
Sealed box volume: 1.5-6.00 cubic feet
Ported box volume: 3.0-6.0 cu. ft.
With this amp pushing both:
KICKER ZX1500.1
RMS Power: 1500 Watts x 1 @ 2 Ohm
RMS Power : 750 Watts x 1 @ 4 Ohm
Number Of Channels: 1
Low Frequency response: 20 Hz
High Frequency Response: 200 Hz
Signal To Noise Ratio: >95dB
Active Crossover: 24 db/octave, variable 50Hz-200Hz, Low pass only
KICKQ Boost: Variable to +18dB
12db/octave subsonic filter defeatable at 25Hz
Built In Crossovers: Yes
Channel Separation: Yes
Class D Design
Gain and crossover frequency control
Protection light indicator
Mosfet Powered
Soft Start turn-on
Protection Circuit
Remote bass control
Dimensions: 20" (L) x 2-1/8" (H) x 9-5/8" (D)
And can I leave the original 4guage wire (maybe 8, I forget) that I'm using to my battery right now? Or do I have to change it for the high wattage? I don't think I'll run over 1000 with that setup though?
2 of these:
KICKER S15L7
KICKER ZX1500.1
Class D Design
Mosfet Powered
Soft Start turn-on
Protection Circuit
Remote bass control
