Source for weld wire? Or even a picture
drpeeb
FL
I can't figure out how "weld wire" can be suitable for a power lead ... unless it's insulated??
If so ... where do you get it? I can't imagine a local welding shop would have use for an insulated wire ...
Is it copper? If not, what's its reistance?
its not "weld wire" its welding cable and yes its copper and insulated.it has very low resistance and can be found at AIRGAS,a welding supply store.you probally have one locally.its usually $50-$60 per 25ft roll for the 1/0
you cant imagine a welder wanting to have his welding leads with high voltage passing through them insulated? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Ah ... I gotcha. I was focusing on like the weld sticks, the consumable wire, not the power feed for the welder itself.
Wonder if welders are P.O.'d since I assume welding cable supply companies now realize audiophiles are buying the stuff ... driving the prices up.
Then again, how often do welders need to replace their welder power feed cables??
drpeeb
drpeeb
FL
tuck05
