Soundtream question
95Prober
Hi
I have a Soundstream Rubicon 604 (4-channel amp) and I have a question about a setting underneath the amp.
There is a switch to select either : "Local" or "Remote". I will be using all 4 channels for the front and rear speakers in my car.
What should I set this setting to and what do they mean? Thanks
If your going to run a true four channels with four rca inputs then select remote. If you going to use only 2 rca inputs then select local.
If you select local then the input signal from channels 1&2 will be also used for channels 3&4. If select remote then all channels will have to have their own RCA inputs to get any output on that channel.
Clear as mud?
95Prober
95Prober
Canada
Blazemore
