SoundStream Vs EarthQuake
mike_cy
CY
ok ok ok my last thread before i buy one //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif :)
SOUNDSTREAM RUB600-4
($280)
Fully regulated MOSFET power supply
RUBI™ (Rapid-Use Branched Impulse) proprietary power supply topology
STACT™ (STabilized Apex Current Topology) Reduces power supply stress by 50%
Trident™ amplifier protection topology
Hawkins Bass Control™ Proprietary bass equalization topology
IDI™ (Intelligent Distress Indicator) gives visual indication of amplifier protection status
Harmonic Bass Alignment™ produces tighter, more accurate bass
Power Grid™ design optimizes current delivery to and from the power supply
Chassisink™ Semiconductors are situated between the circuit board and heat sink
for optimal heat transfer
Ultra-Low ESR Capacitance Bank ensures rapid power delivery for dynamic peaks
Drive Delay III™ A 3-second power supply delay to eliminate "turn-on" pops
Auto High Current™ matches the amplifier to virtually every load application
Differentially Balanced RCA Inputs optimize noise rejection
Fully Balanced PS-2 Input for the ultimate in noise rejection and improved S/N Ratio when a BLT or BLT4 is used
Continuously Variable Low and High-Pass Crossovers
Independent L/R, continuously variable input gain controls
Symmetrically discrete balanced Class A drive boards for linear performance while driving low impedance loads
Platinum RCA Inputs and Outputs
Platinum Power Connectors
Line Outputs
Tri-mode operation
No. OF CHANNELS: 4
OUTPUT (watts):RMS @ 4 Ohms 80x4
RMS @ 2 Ohm 150x4
RMS Bridged @ 4 Ohms 300x2
EarthQuake PH150.2
($380)
* Four channels of amplification
* Two built-in variable crossovers - VARIXR
* Low pass, full range, or high pass operations.
* Four independent low level RCA inputs
* Four crossed audio signal RCA outputs
* Two equalizers (ELC) - Equal Loudness Controls
Max Power output: 1000 Watts
260 W x 2 into 4 ohms RMS
130 W x 4 into 2 ohms RMS
85 W x 4 into 4 ohms RMS
so which one would you choose if you wanted loud clean sound? or just clean sound
i have 2 amps from Earthquake but the one plays the sub VERY VERY good, and the other my rear speakers only..... i'll put this one to play my 6x8 when i will buy the 4chan amp.
//content.invisioncic.com/y282845/emoticons/chicken.gif.218ea7401db50d5e31a7e0b37e05e21e.gif//content.invisioncic.com/y282845/emoticons/chicken.gif.218ea7401db50d5e31a7e0b37e05e21e.gif :chicken:
He can only order from one website and I forgot which one. Not sure if it is millionbuy.com or not. I'm trying to convince him to go Soundstream in all his threads //content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif
I was hezitating to buy SoundStream because noone sells this brand here and if it brokes....it broke...
I hope we choose the right soundstream model //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thank you again all for the patient you show //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
mike_cy
mike_cy
CY
mike_cy
