Need Amp for CDT CL61A's
Wow..let's narrow it down //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif How much you wanna spend?
well you can get a 200-300$ amp for $150 if you go with the us acoustics USX2100. a very solid, reliable amp that you shouldn't have any problems with. i have this amp and it is perfect for the cdt-61a's (which is what i'm running it to). so clear and it never gets hot.
I had this same amp installed about 9 months ago with no issues whatsoever which make all this odd
10
11
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
darrellred
darrellred
arlington, Tx
ngsm13
Bobbytwonames
    Jul 20, 2024
Bobbytwonames
    Jul 20, 2024
