Soundstream RF60C comps
Soundstream Tarantula SST5.7
Soundstream PCT 5.2
Soundstream PCT 4.5
Vibe audio Square 6x9
All Items are BNIB
VIBE
# 6" x 9" 2-way Coaxial Black Death Rectangular Speakers
# Power Handling
* Peak: 600 watts per set / 300 watts each side
* RMS: 200 watts per set / 100 watts each side
# Absorbing polypropylene woofer cone for enhanced depth and clarity of bass
# UV and water resistant construction
# Butyl rubber surrounds
# 2" Aluminum midrange driver
# 1" Titanium dome swivel tweeter
# Rubber gasket ensures a perfect seal
# Cast aluminum angular torsion chassis
# Protective removable ABS grilles
# Single spider design provides control and stability
# Single 40 oz Ferrite magnet
# Rubber magnet boot protects the magnet and can be removed for shallower installation depth
# Separate passive crossover network
# Screw down terminals
# 2-1/2" Voice coil
# Sensitivity: 93 dB
# Frequency Response: 30-25,000 Hz
# Impedance: 4 ohm
# Mounting Depth: 3-15/16"
# Mounting Diameter: 6-3/4" x 8-3/4"
Make offer
Soundstream RF60C comps Soundstream Tarantula SST5.7 Soundstream PCT 5.2 Soundstream PCT 4.5 Vibe audio Square 6x9
To be determined...
(List pictures in this section, 1st picture should be your username/date if
you have less than 10 positive feedbacks with the i-Trader system or less than
10 references that you have sold to in the past. (These must be listed in your
signature, or a link provided to a feedback thread listing these references)).
Soundstream PCT 5.2
Soundstream PCT 4.5
All Items are BNIB
VIBE
# Power Handling
# 2-1/2" Voice coil
# Impedance: 4 ohm
Make offer
To be determined...
