Soundstream SPLX 15's
AnthonyO
Budget Banger Connoisseur
I have a chance to get two SPL-X 15's for $310 shipped to my door. Excellent condition. Heres my dilemna, I am running a Soundstream RUB1.2500d. As you all know, these subs are dual 2ohm. So I can only run them at 2ohm mono on the Rub1.2500d as its only 1ohm stable and not .5ohm stable. So I will only be putting 1700 watts to these if I get them. Subs are rated at 1250RMS.
I am so confused on what to do. Help a brother out.
Not too bad, no. I've seen a pair of HX on a PB XA4000 though so it depends on what you're trying to do. I will say they will take a good bit of power (this all referencing the HX series). I'm not 100% on the HF as I haven't run that exact series nor seen them in action.
had same setup, aslong as u got the power/juice 0Gauge,big3,H/O alt, atleast 1 xtra Batt, tha rub1.2500 will go .50 ohm, with rise you'll be good, you'll be happy, very, but if u skuuurRed down do it! holla @me for pix, vid demo
My buddy had two D2 L7 12's on his Rubi 2500d, we had it @ 2 ohm in his Firebird and did a 141.3 at the dash sealed, I dropped the amp to .5 ohm and did not touch a setting and we burped a 144.3 first time out. I've had four of those amps, and ran them successfully @ .67 and .5 ohm each daily. I also have three SPLX-HX12's, and would love to try the HF's out as they are the burp subs (High Frequency / HF)
AnthonyO
AnthonyO
Minot, North Dakota, United States
shaggyshag
