Soundstream Amps - D200ii and D60ii
btolenti
Soundstream D200ii (x2)
Soundstream D60ii (x2)
Selling two of each. First two I have pics for are the better of each pair. Both were tested over the weekend and work great. For their age, they really are in spectacular condition. I was going to use all of them in an SQ build in my wife's car, but plans have changed and I need to sell these to replace some amps in my daily driver. Pictures for the other two amps should follow tomorrow once I get them down from storage and test them.
Asking $140 each, shipped for the D200ii's OBO
Asking $70 each, shipped for the D60ii's OBO
See above. Slightly better price if picked up in Orange County.
So, the other D60 tested out just fine. However the other D200 has an issue - it blows the main fuse when power is applied. I assume it's something that Amp Medics or DB-r can fix. Either way, pics are below. For the broken D200, asking $80 OBO.
Specs are available here:
http://www.soundstream.com/manuals/AMP/sa_mc_d_class%20a/d_ca/d_ca.pdf
D-200 II
Power Output-Impedance Optimized Setting
100 W/ch X 2,20Hz - 20kHz Into 4ohms
100 W/ch X 2,20Hz - 20kHz Into 2ohms
200 Watts Mono, 20Hz - 20kHz Into 4ohms
140 W/ch X 2, 20Hz-20kHz Into 2ohms
240 Watts Mono, 20Hz-20kHz Into 4ohms
Total Harmonic Distortion
S/N Ratio: 110 dB
Damping Factor: > 200
Input Impedance: 1Ok
Idle Current Draw: 1.2 Amps
Maximum Current Draw: 26 Amps
Dimensions: 11 “W X 7.8”D X 2.13”H
Input Sensitivity: 250 mV - 2.5 V
Bump for father's day offers!
$65 shipped for the D60s and $70 shipped for the D200?
Steve at Amp Medics said they handles repairs on D200s...
would you do 50 on the non-working d200?..... and that's not a typo. many ss amps from the 90's used to have hc/hv settings. the 4ohm@100 is in high voltage, and 2ohm100 is in high current. 4ohms in hc mode would be only 50, and 2ohms in hv would be abusive, and blow the output fuses.
btolenti
btolenti
Orange, CA
dacheatham
