Sound system for my A Class w176
gmaister22
Hello guys!
I want to purchase a good sound quality system for my Merc A Class (2014 model)
I am located in Europe and Audison speakers and amps are priced okish here i think.
I was having a look at the AV 5.1k which would be great with the addon for a digital setup...what do you think? What systems would you recommend?
I was thinking spend a total of 1500-1800$ at max (the lower the better)
PS: I love bass!
Hello guys!
PS: I love bass!
The AV5.1 is a nice amp... Cant go wrong with it.. with 1k on tap @2ohm power wise your good for a nice bass setup... Box is really the key factor...
Name the factory sized speakers in that car.
What's with those measurements? And are they in millimeter?
I would guess so, that they are in millimeters. I found the pictures online.
Hmm no clue whats the inches of the factory sized speakers //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
You have (5) 3.14961" center speakers in the car... (4) 1.692913" tweets and (4) 6.496062992 mids "1 per door" and (1) 7.874015748" sub or (1) 10.6299213" sub depending on what type A class...
Ok, if you say so //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
So what setup would you recommend? I have an A200 model
Keeping brands constant can help with impedance matching and power. Companies design their products to work well together. That said, no issue mixing and matching. JL does make good stuff but they have an odd mix. The W7 is too beefy but loud. The W6 isn't as SQ as before. W3 is flexible but cheaper and limited. TW5 is good for a thin sub. TW3 is the budget thin sub but a good thin sub. If you're stuck with a thin sub due to mounting location, then the TW3 is a good choice.
Sent from my SM-G900V using Tapatalk
gmaister22
gmaister22
GREECE
keep_hope_alive
