sound deadening
Nizzel
I am in the process of deadening my entire trunk with secondskin. I have never done this before and am kinda just working my way through it. Now, I am currently doing my trunk lid and am wondering exactly how I go about deadening the trunk lid the correct way. The way my trunk is set up (2002 Altima) is there are a couple big openings in the lid itself (about 4 inches in diameter). I am not sure how to go about the job because of these. Do I just put some deadener over the holes and simply cover them? Or should I just cut the deadener to a shape that fits the trunk lid by going around these holes? Again, I am new to this and any help would be appreciated
Deadener only "really" work when it is directlr on the surface; do not just go over large holes. Try cutting a few small pieces and stick them down inside. Also you can use foam padding and stuff it into the cavity.
Secondskin is better/cheaper than dynamat, and more versatile. You will also support one of the 'little guys' as opposed to a big corporation when buying from them, so what do you have to lose?
Nizzel
Nizzel
Los Angeles, CA
packerfan
vegang
vegang
