Sony ES XM-601GD
ciaonzo
TheContinental
11,703
76
WI
Sleeper of an amp. Ugly as can be, but built well and makes the power. Runs all day at 1ohm.
Used. A few marks but works perfectly. Three 25 amp fuses.
Linky--> Sony ES XM-6001GXD 300W x 1 Car Amplifier at Crutchfield.com
  • Supply voltage for power ratings: 14.4V DC
  • RMS power at 4 ohms: 300 watts x 1(20-300Hz, at 0.2% THD)
  • RMS power at 2 ohms: 600 watts x 1(20-300Hz, at 0.6% THD)
  • RMS power at 1 ohms: 1000 watts x 1(20-300Hz, at 1.2% THD)
$125 shipped.
CONUS only, please.
How the fook do you still have this?? I do not need an amp and I'm tempted... Lol
Thanks. The stigma of running Sony.... Hard for some to play off. My front stage is Sony powered until I switch over to all Zed but it's beautiful as is.
856
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
That looks like it can work for backup cam for sure, thanks
976
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
    May 31, 2024
    May 24, 2024
