Sony cdx-u6260
the owner's manual will usually list compatible accessories and changers.
https://docs.sony.com/release/CDXU6260.PDF
but while this is a very in-depth manual, it lacks that information.
Here is a changer list
https://docs.sony.com/release/ChangerMagazinesupplement.pdf
any changers made around the same time as the head unit will likely be compatible if the BUS connector is the same. The head unit was made in 1993.
you can go through the links here, look at the manuals for each changer, and find changers from the same time-frame with the same connection.
https://esupport.sony.com/US/p/select-system.pl?PRODTYPE=121
Sturm
Sturm
minneapolis
keep_hope_alive
vegang
vegang
