sony CDX-GT56UIW
  • 6
garretttt4
big pimpin
2,575
Watertown sd
Like new. Used for like a week. Usb front and aux front and rear.
25+ shipping.
On you. Should fit in flat rate box so it shouldnt be much.
Features: Detach face with front aux input Easy-to-read single line LCD display MP3/WMA/AAC playback Digital Music Plus, a Sony codec enhancer RCA outputs for external amplifiers Built in electronic HPF/LPF crossovers Wireless remote card SiriusXM Satellite radio Advanced Sound Engine Radio Data System Front USB 1-Wire Connect, charge, and control your iPod2, iPhone2, Walkman player or other compatible USB devices Intuitive Search Features Automatic Level Optimizer Key illumination Passenger Control Pause, Repeat, Resume Play and Shuffle function ZAPPIN feature MP3, WMA, AAC1 codecs Jump Mode 16 Pin wiring harness connector Black Trim Ring -8dB / +18dB Level Adjustment Automatic Level Optimizer Front Aux-In DM+ (Codec enhancer) EQ : EQ7: 7 band EQ with +/- 6 dB adjustment Selectable on/off High Pass Filter at: 50, 60, 80, 100 or 120 Hz Dynamic Loudness Selectable on/off Low Pass Filter at: 50, 60, 80, 100 or 120 Hz. Output Power (4ohm, 1kHz,16V)(W) : 52 watts x 4 Rear / Sub switchable Rear Bass Enhancer Sub initial Sirius/XM Connector Time Alignment Custom Time Alignment Preset Auto off mode : Yes Manual Dimmer Adjust CD lock mode 12 Hours clock Optional RM-X4S Rotary commander Detachable LCD Display Black color / Negative Display color Black (Bare) Panel FM18/AM12 Preset RDS/EON (NA Only:RBDS, Others:RDS) Output power : 17 Maximum output power (4ohm, 1kHz, 16V)(W) : 52 220 Preout impedance 2 Preout output level FM: Channel separation: 50 dB at 1 kHz FM: Frequency response : 20 - 15kHz FM: Intermediate frequency (MHz) : 25KHz FM: S/N ratio (mono) : 80 dB stereo FM: Selectivity (400 kHz) : 75 dB FM: Tuning range (MHz) : 87.5-107.9 MHz FM: Usable sensitivity (75 ohm) : 8 dBf MW: Tuning range(kHz) : 530-1710
found these specs on-line for you.
Thanks! And bump.
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
720
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
garretttt4
big pimpin
garretttt4
Watertown sd
wErd
    May 16, 2024
    May 16, 2024
