Sold Some Stuff...
Alpine CDA-9815
I'm going to be changing my system set up... so this stuff may go. I'm not looking for trades. Everything works just fine. Also pics were taken at random times (all within the last 2 weeks) and I'm too lazy to take new pics with name/date.
12" Fi Q (dual 2 ohm) also as you might can see it has a scuff on the surround @ 7:30ish o-clock it does not effect the sub.
Q12
DUAL 1 | DUAL 2 Fs: 28.4 Hz | 27.1 HzRe: 0.7 Ohms/coil | 1.4 Ohms/coilQms: 05.39 | 5.63Qes: .49 | .48Qts: .45 | .44Mms: 211g | 231gCms: 0.15mm/N | 0.15mm/NSd: 481cm^2 | 481cm^2Vas: 48.3 l | 48.3 lSpl: 85.4dB 1W/1m | 84.8dB 1W/1mBl: 10.4 N/A | 15.1 N/AXmax: 27mmRms: 1000WSealed box: .8-1.5 cuftPorted box: 1.8-2.5 cuft @ 28-33HzSub OD: 12.500” Cut ID: 11.125” Mounting depth: 7.000” Displacement: 0.16cuft
$170 shipped
CDT EF-61CF's (still in car, used for a week so far)
6.5" 2-way
Midrange: 6.5" Cast
Crossover: SatNet-480 Elliptic
(CDT has added functionality and quality in this module with provision for an extra tweeter. Satnet 480 is an upgrade of Satnet 456 with an extra set of terminals for an image tweeter. This operates in parallel the main tweeter. Both are protected. The film capacitors are larger. Level control is by slide switch instead of jumper.)
4th order2-way
Tweeter: 1" Smooth Silk Dome
Power handling: 140 watt RMS
Frequency response: 55-20kHz
Sensitivity: 90.1 dB.
Impedance: 4 Ohm
Surface & flush mount tweeter
$180 shipped
12" Type R (dual 2 ohm)
RMS Power Range : 50-500 Watts
Peak Power Handling: 1500 Watts
Impedance: Dual 2 Ohm
12" component subwoofer
Kevlar-reinforced pulp cone
Cast aluminum frame with perimeter venting
Dual 2-ohm voice coils
Low Frequency response: 24 Hz
High Frequency Response: 500 Hz
Sensitivity: 87 dB
$90 shipped
Memphis 16 PRD1000.1 (comes with gain knob)
Class-D Monoblock Amplifier
RMS Power Ratings:
300 watts x 1 chan. @ 4 ohms
600 watts x 1 chan. @ 2 ohms
1000 watts x 1 chan. @ 1 ohm
Black Textured Finish Heatsink with Black Chrome Trim and Injection Molded End Plates
Fully Variable Low-Pass Crossover (50 - 350 Hz)
Power and Protection LEDs
Adjustable Gain Control
0 - 18 dB Bass Boost
Subsonic Filter: 20 - 50 Hz
Low Level Input
RCA Outputs: 1 Pair
Optional Remote Gain Control
PWM MOSFET Power Supply
Platinum Finish Terminals
Dimensions: 9.5" W x 2" H x 10.75" L
$150 shipped
Memphis 16 PR100.4
400 watts MAX, 4 Channel Car Amplifier
RMS Power Rating:
4 ohms: 50 watts x 4 chan.
2 ohms: 70 watts x 4 chan.
4 ohms Bridged: 100 watts x 2 chan.
MOSFET Power Supply
Heat Sink Equipped
High Level Inputs
RCA Level Input
18 dB per octave, Variable High Pass, Full Pass, and Low Pass Crossover
Tri-Mode Operation Capable
Overload, Short Circuit, Thermal, and Reverse Polarity Protections
Fan Cooling
Bass Boost: 0 - 9 dB @ 45 Hz
Dimensions: 14.25"L x 9.37"W x 2.6"H
$130 shipped
I wish i could snag that FI, but right now i just can't make it happen plus i dunno how loud it would be off 600w in a sealed enclosure. Bump for you
I ran it at 1000 watts and it got pretty loud, but it was in a 0.9ft^3 sealed box which was kinda small for it IMO. It could get loud off the much power, depending on the install.
Well for this weekend I will cut the prices since I want to sell this stuff to finish my new set up.
Fi Q... $160 shipped.
CDT's... $170 shipped
Type R... $80 shipped
1000.1... $130 shipped
100.4... $110 shipped
Alpine CDA-9815
Alpine CDA-9815
BFE
Alpine CDA-9815
