some problems....
installed the new HU today....
Problem 1: not getting any sound out of ANY of my speakers.
Problem 2: Kicker amp will NOT turn on, but lanzar does, no sound though
Problem 3: still not saving settings. need to run a wire from my battery to my HU for standby power.
input??
well if you kicker amp is not turning on, it probably is not getting power. might wana check that.
and if the kicker is powering speakers. of course you wont have sound if the amp is not on
and the thick Yellow wire on your HU needs constant power. and red wire goes to switched.
well the HU is operating on switched power then... cause that ish goes off when the truck is turned off
Lanzar amp is on, so subwoofer should be on, but it's not
You should have an orange or yellow lead for memory. If you don't have a connection for it in your dash then maybe you could run it to your fuse box and jump it to something that's always live, like your cigarette lighter or dome light.
Ku-sama
Banned
Ku-sama
Dover, PA
Ku-sama
