Some Dimming
after a while check to see if you get build up on your battery terminals. If you do I probbably would go to an agm battery under the hood like a kinetik. also big 3 is your friend and a cheap upgrade even if you do it in 4ga wire.
Before I put the stereo equipment in my car it would get bad build up on the terminals. So I put some of those pad things on there to stop it. Its working somewhat.
I read how to do it and it seems like it takes alot of work to do.
All you need is 3 runs of wire, 6 terminals, a ratchet/wrench set, and some spare time man. Easy upgrade and your car's electrical system will thank you //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Well the big 3 will help stabilize the voltage it might not help with dimming.
I have a 130a alternator and a 1 year old battery that reads 12.6v off the posts and i get dimming after volume 19 of 22 listening volume. Its just something that is hard to avoid.
The big three did allow me to get a nice 14.4v to the amp though.
My advice since there is slight dimming is to do the big 3 with some 0g wire. There's a thread dedicated to showing you how it's done. Doing this will increase voltage from your alternator to your battery. Try knukonceptz wiring, cheap and good quality.
shakewell519
shakewell519
Augusta,Ga
Louisiana_CRX
