Sold Solid Audio F2500D
infamous_e46
hArRy_DaNgLeRs
Power Output
RMS @ 4 Ohm: 700W x 1 Ch.
RMS @ 2 Ohm: 1300W x 1 Ch.
RMS @ 1 Ohm: 2500W x 1 Ch.
RMS @ 1 Ohm: 4000W x 1 Ch @18v
Signal to Noise Ratio: >100dB
THD (IHF-A): 0.2%
Input Sensitivity: 0.15V – 5V
Input Impedance: 47KOhm
Slew Rate: 10V/USec
Damping Factor: 300 @ 4 Ohm
Fuse Rating: EXTERNAL 200A Fuse
Dimensions (in mm):
Width: 240mm
Height: 61mm
Length: 570mm Features
MOSFET Power Supply Amplifier.
Double Sided Through Hole Epoxy PCB.
Gold-plated Brass Set Screw Terminals.
24dB/Oct. Crossover - Variable Low Pass Crossover (40Hz ~ 200Hz)
Variable 24dB/Oct. Subsonic Filter 10Hz ~ 70Hz
Variable Phase Shift
5 Way Protections
Daisy Chain Through Output RCA
Bass Remote Control
Power/Protection LED
1 Ohm Stable Circuits
Soft Start/Output Relay
18V Operation
Parallel Operation
405 shipped conus including all fees o.b.o
http://www.talkaudio.co.uk/vbb/showthread.php?p=1366013
http://audioforum.termpro.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=20;t=012611;p=0
the solid audio 2500d's were pretty much the same as IA 20.1s (but with a couple more caps)
badass amps my mate was running 2 strapped at 0.5 for daily (0.25 per amp!)
http://audioforum.termpro.com/topic/20/10916.html
http://audioforum.termpro.com/topic/20/11585.html
//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
rosrock
