solid amp for two 12w6's
M@nJo
running 2 12w6v2's (dual 4ohms) in a sealed box currently powered with a bxi1606d. im thinking of selling the amp to a local buddy and finally get a SOLID amp to power my subs. ive always owned hifonics and would like to try something 'better'. with a $300 budget, what would you recommend? must be 1ohm stable and 1000wrms.
SAX1500D
# 1500 x 1 watts @ 1 ohm
# 800 x 1 watts @ 2 ohms
# 400 x 1 watts @ 4 ohms
# 0.2v - 6v adjustable input sensitivity
# 10 Hz - 350 Hz Frequency Response
# >90 dB dB S/N Ratio
# 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
# Linkable to another SAZ-1500D for up to 3000 watts @ 2 ohms
# 35 Hz - 300 Hz adjustable 24dB Low-Pass Crossover
# 10 Hz - 60 Hz adjustable 24dB Subsonic Filter
# 0 - 180 degree adjustable phase shift
# 0 - 18 dB adjustable bass boost with 45 Hz center frequency
# Wired Remote Control unit included
# 4x 40 Amp Internal Fuses
# 17" L x 9" W x 2" H
# $599 US Dollars - MSRP
SAX100.2
# 100 x 2 watts @ 4 ohms
# 200 x 2 watts @ 2 ohms
# Damping Factor > 350 @ 4 Ohms
# 10 Hz - 40,000 Hz Frequency Response
# Channel Separations: 75 dB
# > 90 dB S/N Ratio
# Selectable HP / LP / FULL crossover
# 35 Hz - 300 Hz adjustable 18dB Low-Pass Crossover
# 75 Hz - 2,000 Hz adjustable 18dB High-Pass Crossover
# 3x 20 Amp Internal Fuses
# 13 3/8" L x 9" W x 2" H
# $299 US Dollars - MSRP
Not sure if this helps but i try:)
M@nJo
M@nJo
bay area
KLUVKUSTOMS
