sold RFpunch amp,...is this Memphis an upgrade or downgrade
drwang
I sold a Fosgate Punch P8002 amp. I'm thinking about getting the Memphis 16-PRD1000.1 but not sure if this is an upgrade or downgrade lol. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Did I make a mistake by selling the Punch amp? Everyone was bashing on my new school RF amp. Not that I felt peer pressure, but I want something better. Thanks guys.
* Amplifier Type: 2-channel
* RMS Power @ 4 Ohms: 200W x 2
* THD at 4-Ohm RMS Power: 0.08%
* Bridged RMS Power @ 4 Ohms: 800W x 1
* Speaker Level Inputs: no
* Preamp Outputs: yes
* Built-In Crossovers: HP/LP
* Bass Boost: 0 - 18 dB
* Frequency Response: 20-20,000 Hz
* Signal to Noise Ratio: >80 dB
* Fuse Rating: n/a
# Class-D Monoblock Amplifier
# RMS Power Ratings:
# Black Textured Finish Heatsink with Black Chrome Trim and Injection Molded End Plates
# Fully Variable Low-Pass Crossover (50 - 350 Hz)
# Power and Protection LEDs
# Adjustable Gain Control
# 0 - 18 dB Bass Boost
# Subsonic Filter: 20 - 50 Hz
# Low Level Input
# RCA Outputs: 1 Pair
# Optional Remote Gain Control
# PWM MOSFET Power Supply
# Platinum Finish Terminals
# Dimensions: 9.5" W x 2" H x 10.75" L
# Number of Channels 1 - Mono
# RMS Power (4 ohms) 300 watts x 1 chan.
# RMS Power (2 ohms) 600 watts x 1 chan.
# RMS Power (1 ohm) 1000 watts x 1 chan.
# Peak Power Output 2000 watts
# Min. Impedance Unbridged 1 Ohm
# THD @ Rated RMS Power 0.05%
# Amp Preamp Outputs Yes - 1 Pair
# Built-in Crossover LPF(50 - 350 Hz), Subsonic(20 - 50 Hz)
# Signal-to-Noise Ratio 90 dB
# Bass Boost 0 - 18 dB
# Fuse Rating 40A x 4
It shows memphis has a THD of .05% and the RF of .08%. The memphis is lower....even at that little difference you wont notice anything. Even if the Memphis was at 1% I highly doubt you would notice a difference.
You're right, I just noticed that and edited the first post lol. I was looking at another amp while I posted this so I got the ratings mixed up.
drwang
drwang
Bay Area, CA (415)(925)(831)
Max_Power
