So I got this ed "a v2". pics inside.
The frame differences has already been discussed. Aesthetically the frame will appear similar to JL's, but the two copywrited technogies (revolving around the direct cooling passages on the W7) were removed before regular production started.
In other words, eD already got caught trying to copy the W7 frame, so you wont find the copied tech on any actual released model. Comparing current frames will prove nothing one way or the other.
NA RSX, your 'joke' about me was hillarious. No really.
I know. however i am still curious as to some of the similarities/differences in them:)
Just keep in mind eD also changed the aesthetics of the frame to look less like the JL frames as well. The proto frame they released pics of originally looked more like the JL frames than the production model does.
I believe audiojunkies has a webpage dedicated to the comparison of the two subs side-by-side. Would be cheaper than buying a W7 to see for yourself. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
tank you tank you
the first spider roll being filled with glue is enough for me to want to wipe my *** with the rest of the soft parts, what a bunch of incompentent retards, the glue woudl cause the spider to fail premature on any sub with enough normal usage, it might even limit the stroke some and give different amounts of rebound between first and second spiders, it all adds up to a big steaming pile of Eduh.
visitor
Banned
visitor
IOWA
Haunz
