Smallest Dimension for a XXX 15
ChiefontheDitty
I was wondering what the smallest dimensions the XXX could be ran on for a ported box. The problem is it is almost impossible to get a box in my trunk. So if someone could give me a suggestion of some small dimensions for the XXX or dimensions they have used in a WRX sedan before. Thanks, Chief
Oh I just assumed that the snailshell design was a small enclosure. I guess I really want to know if I can put the XXX in a small ported box.
Sure you can put it in a small ported box. You will loose some low end. Probly gain a little output but in the upper range. I'd go sealed. It really depends on how "small"
I had a box designed by Moe Lester and I built it and all, then I went to put it in the trunk and it didnt fit. I was to lazy to go measure one little section and it screwed the whole thing up. But the dimensions were: w26, d28, and h16. The problem was the depth was to much so it would go in then it would hit the bottom of the trunk and the rear window and not move.
I have also tried a few subaru specific forums to try and see what everyone elses dimensions where. But all I could find was a guy who built his in his trunk, and a hole lot of people asking why do I need a big box for the sub and who is RE. Its Crazy. Chief
ChiefontheDitty
ChiefontheDitty
Sweetwater, TN
ChiefontheDitty
