Small setup for a fusion hybrid
shrowihr
Just highlighting the box build on this one as not much is going into this car. It has the factory nav and premium stereo so i'll use a loc to hook this up. It also has a navigation overide device that i purchased from coastal tech so that we can play movies on the factory screen while driving down the road.
After getting this installed i have a bit more information on this. The factory sony amps are on the passenger side and there are 2 of them. one to run the mids and high and one to run the 2 factory subs(they are 6X9 in the rear deck). Once you pull the carpet off the wall you can see the bigger amp and the smaller amp is behind it.
Here is the factory sony amp for mids and highs already unbolted
Here is the sub amp. It is probably the size of a coke can
I placed the line out converter after the sub amp because honestly... how much power is it really putting out? not much more than an aftermarket headunit.
Here is what it looks like in the car with everything put back
shrowihr
shrowihr
dslfih,woiju
shrowihr
