Small Package Big Punch
LiMarc
I Plan on Running a PDX 5 (300W RMSx1 @1-4 Ohms) I've got an 07 Ram, Im Looking to put a single sub under the Back seat.
The problem is the boxes i've seen only have a mounting depth of 5 3/4. I can't seem to find a Sub that small that can haddle that much power Any help would be great
Thanx
I checked out the ID's and i might be able to fit the ID10's, the website didn't have the mag dia Do you know where i might find that info
The box specs are 5in dia @ 5 3/4depth......6in dia @5 3/8 depth. The ID10s fall right between
http://www.imagedynamicsusa.com/manuals/iD/ID10D4v3.pdf
I checked out the Slim Pioneers too thier only rated up to 250w Nominal Power (is nominal the same as RMS?) will that be enough. Also i've heard bad things about Pineer Subs do these Slim lines pass the test?
Mag V4 preorder! new Mag is less thatn 5" deep.
true, isnt the bm gonna be even slimmer? if your mechanically inclined you could replace the lower half of your front jump seat with a fiberglass box, mine is 1cube and really blends well with the front stage.
LiMarc
LiMarc
Long Island, NY
LiMarc
Mike Mccabe
