Small hidden or almost in the way?
NNUTTHOWZE
So im planning on getting a sub very soon and I am strattling the fence on two subs and different boxes. I drive a 07 f250 crew cab. JL makes a stealth box for their 13 TW5 ($1,400 sub amp box) that goes under the rear seat which is one choice or Im really liking the 10W7 ($920 sub amp box) with the prowedge box which I would set behind my center console in the rear floor board. Which would be better sounding and more worth my money?
There is an enclosure discussion board here. Just post up your measurements of both areas. Ask nicely and I'm sure someone will design you a box to fit. From there take your cut list to lowes and have them cut the pieces for you. Just buy screws, wood glue and a cordless drill if you donHt have one. All said and done you are out $100-200 depending on drill. Much better than a grand. If you don't trust yourself, have it done by a competent member. A shop may or may not build a good box. So better to find someone who can or learn yourself. It is not hard at all to build a sealed enclosure.
NNUTTHOWZE
NNUTTHOWZE
Leesburg, VA
bugflipper
