Small 800watt plus amps
Gods_Prototype
I need either one amp that is 1500W-2500W that is under 14"X10"X(height doesn't matter) or two amps around 800W-1200W that will fit in that space, if I go with two they will each have their own 14"X10" space.
Is there anything resonably priced?
Amps need to be either two 2ohm or a single 1ohm. I have two 4ohmDVC subs.
I can spend no more than $350 per amp on 2 smaller ones or $550 on one big one.
Ive been looking at
two Alpine MRP-850 cheap and fits in the space
two Rockford T600-2 Easily puts out 1000W into a 2ohm load bridged
one Rockford T1500-1bd I don't know of anyone using this before.
any suggestions?
If there is some really good deal I might be willing to make a different Amp rack but as of now thats what is limiting me.
Anybody think buying two refurbished Phoenix Gold Xenon X1200.1's would be a good idea. Ive never used refurbs before. They are only $330 each?
Those are pretty small dimension for 2000w of power. Alpine's PDX-1.1000 does 1000w and is pretty small, 8" x 10", I think. These amps are "stackable", one on top of the other...
Its for two 15" type R's. box is around 8 cubic feet and 29hz tuned port.
I would pick up the those alpine amps in a flash if they could be had for cheaper than anywhere Ive seen them. Cheapest Ive seen is almost $500 for one. The rockford T600-2 should give comparable power at way cheaper price in a small package. I've kinda been looking at mmats amps too, they look small and powerful but they are like almost $900 for one that meet my power needs. I was ordering a zx2500.1 but they backordered and I cancelled it because I figured I could get something that fits my amp rack which might not be the case.
Im not looking for cheap power but I can't afford top of the line either, so kicker or rockford would be the most I'm willing to spend. Cheaper the better but I don't want garbage, Ive had hifonics brutus and rockford power amps and the difference is crazy IMO.
I found a good price on a zx1500.1 but I'm not to sure I could run it at 1 ohm daily. Anyone know where to get those Alpine M-1005(i think is the model). I had one of those on one of my 15"s and it did the job but when I went to buy them they were sold out.
I'm probably going to end up getting the two rockford power t600-2. They fit my amp rack but they will run at 2ohm bridged, I just talked with a rockford tech guy and he said they will do it but they will run hot, plus they will match my t400-4. Im a sucker for rockford power amps, I just wish they would tell you the power they put out before you buy them. My little t400-4 puts out something like 250X4 @1ohm. Right now it can power both 15's but they can handle a lot more. Its funny buying a 400w amp that needs 100amp fuse.
Gods_Prototype
Gods_Prototype
Ontario
dipitydoo
